bluePurpleOne.svgbluePurpleTwo.svgbluePurpleThree.svg
WiFi Pods and Boosters
Find everything you need to know about our mesh WiFi Pods and older WiFi Boosters – from discovering if you’re eligible to order your first Pod, to setting one up or troubleshooting any problems you’re having.
If your home WiFi signal needs a helping hand, our mesh WiFi Pods are designed to do just that. Part of our WiFi guarantee, discover how you can boost your broadband signal across your whole home and get the best possible connection for you and your devices. WiFi Max customer? Don’t forget to download the Virgin Media Connect app to get the most out of our WiFi Pods.
Don’t yet have one? See if you’re eligible to order a Virgin Media WiFi Pod.
What type of WiFi Pod or Booster do you have?
To help you get the information you’re looking for, first choose the type of WiFi Pod or Booster you have. Pods and Boosters work to enhance your WiFi signal in different ways. So, we want to help you make the right choice.
Pick the WiFi Pod or WiFi Booster that best matches the one you have.
imageAlt
WiFi Pod (black)
imageAlt
WiFi Pod (white)
imageAlt
WiFi Booster
WiFi Pod (white)
Using our mesh WiFi Pods (white), boost your home broadband coverage and make sure no room is left unconnected. All the information you need to set up your first Pod or fix an issue can be found here.
FAQs
WiFi Pod (black)
Our new mesh WiFi Pods (black) are designed to enhance your home broadband coverage. From setting up your first Pod to getting help with an issue, you’ll find everything you need to know here.
FAQs
WiFi Boosters
Our WiFi Boosters – also called Powerline Boosters – are designed to help combat WiFi blackspots in your home. They make use of your internal electrical wiring to connect your devices to your Hub – and from any room with a functioning socket.
WiFi Boosters are no longer available to Virgin Media customers. But we can still help you set up a Booster or fix any issues (PDF) you’re having. Our WiFi Boosters guide has everything you need to know to get the best out of a Powerline Booster – and your home WiFi network.
