If you want to stop the Hub from broadcasting a WiFi signal simply follow the below steps. However please note we recommend that you leave the default WiFi settings as they are. If you are certain that'd rather the Hub didn't broadcast its WiFi signal please continue.
How to set up port forwarding
How to set up port triggering
To set up port forwarding
o UDP: selects UDP only
o TCP&UDP: selects both TCP and UDP
o IP Address: enter the local IP address for the computer that is using the service
To set up port triggering
Unless you have a specific reason to do so, we do not recommend manually changing the WiFi channel on the Hub. If you are experiencing issues with your broadband connection, see our step-by-step guide for improving slow WiFi speed .
Got a Hub 3? Checkout how to change the wireless channel on hub
If you still want to manually set your WiFi channel:
Unless you have a specific reason to do so, we do not recommend manually changing the WiFi channel on the Super Hub. If you are experiencing issues with your broadband connection, see our step-by-step guide for improving slow WiFi speed.
If you still want to change the Super Hub’s WiFi channel:
