Learn how to manage or change your Virgin TV standby settings. If the Virgin TV box keeps turning off and you want to know how to stop it from going into standby mode, follow these simple steps below.
If the 360 box keeps turning off, you can change this on your remote control in two simple steps:
From here, you can change your standby settings in the following ways:
This is where you can save energy by choosing how long the TV is idle before it goes into standby mode.
Here, you can choose between Fast start, Active start, and Eco (slow start).
By default, the V6 box will go into standby if it hasn’t been used for four hours. But don’t worry, the V6 box will continue with any recordings you have scheduled.
To change when the V6 box goes into standby, you can update your default settings:
Select from one of the below power saving settings:
The V6 box won't power down. If you want to turn it off, press the On/Standby button on the remote. When the V6 box is in standby mode you’ll see a red light on the front of the box.
To get things started again you just need to wake up the box by pressing Home on the remote.
The V6 box will power down if you don't use it for four hours – but you'll still be able to watch your recordings in another room. When the box is in standby mode you’ll see a red light on the front of the box.
The V6 box will completely power down if you don't use it for four hours – but if you still want to watch your recordings in another room, use the Virgin TV Go app. When the box is in standby mode you’ll see a red light on the front of the box.
By default, the TiVo box turns itself off and will go into standby if it hasn’t been used for four hours. But don’t worry, the box will continue with any recordings you have scheduled.
To change when the TiVo box goes into standby, you can update your default settings:
The TiVo box will remain on until you press Standby on the remote. When the box is in standby mode you’ll see a red light on the front of the box.
As the default option, the TiVo box will enter standby mode after being idle for four hours, but suggestions will be recorded. When the box is in standby mode you’ll see a red light on the front of the box.
The TiVo box will enter standby mode after being idle for four hours, but suggestions will not be recorded. When the box is in standby mode you’ll see a red light on the front of the box.
To save the most power, this setting switches the TiVo box into standby mode after two hours of inactivity – and suggestions will not be recorded. When the box is in standby mode you’ll see a red light on the front of the box.
Yes. You can still record when the box is in standby mode.
You’ll find the standby button at the top of your Virgin remote.
