SSDP Vulnerability alert
You may have recently received a letter and/or email from Virgin Media explaining that we have been notified that a device on your network has a Simple Service Discovery Protocol (SSDP) vulnerability. If you have received such a communication from us, please follow the advice given on this page to resolve the issue.
These fixes are provided as a courtesy and we are not responsible for any problems encountered whilst applying these steps and we are not able to provide any technical support for such problems.
Overview
We work with a number of not-for-profit organisations across the banking industry and security sectors that collate information on devices across the Internet that appear to be compromised or misconfigured.
The Simple Service Discovery Protocol (SSDP) is often used for discovery of Plug & Play (UPnP) devices on a local network. This is commonly used by streaming services and games consoles to be able to cast content between devices.
An SSDP vulnerability is a security issue whereby a 3rd party can use this protocol to gain unauthorized access to your network/devices for malicious purposes. If a 3rd party has access to your network/devices they will be able to perform a Distributed Denial of Service (DDoS) attack.
What has happened?
We suspect a device connected to your home network may have a Simple Service Discovery Protocol (SSDP) vulnerability.
For more information on these reports please visit ssdpscan.shadowserver.org*
If the settings are left open they can be exploited to unwittingly participate in malicious activities, for example a Distributed Denial of Service (DDoS) attack.
It is therefore important that you follow the advice in this article. **
How can the issue be fixed?
The easiest way to deal with SSDP vulnerabilities is to configure your firewall to block port 1900.
It is worth noting that blocking this port will only stop traffic over this port leaving or entering your home network. Services within your home that use this port should continue to work as normal.
Hub 3.0
To close the vulnerable port on the Virgin Media Hub 3.0:
  • Access your Hub's configuration page - default web address: 192.168.0.1
  • Login with your username and password, default will be shown on the Hub itself
  • Select Security on the left side of the page
  • Select the Port Forwarding option
  • Remove any rules that will keep port 1900 open
  • Select the Port Triggering option
Virgin Media Super Hub
To close the vulnerable port on the Super Hub 1 or 2’s firewall:
  • Select Advanced Settings and accept the prompt
  • Scroll down to the Security section
  • Tick the Delete box next to any rules that will keep port 1900 open
  • Click the Apply option
3rd party routers
If you use a 3rd party router in conjunction with the Virgin Media Super Hub or Hub 3.0, your router's firewall will need to be configured to ensure port 1900 is not accessible outside of your local network - this can be performed by blocking the port or removing any Port Forwarding rules for that port. In order to identify how to do this with your particular router, refer to the documentation for your device or refer to the manufacturer's website.
It is important to check all your devices sit behind a firewall. In most cases your firewall is configured as a part of your router, this is the case with the Virgin Media Super Hub and Hub 3.0. If you have specifically disabled the Firewall in your router, it is crucial that you configure your devices to sit behind a firewall that is blocking port 1900. If this does not apply to you, please proceed to the next step.
Modem Mode - If you are using your Virgin Media Super Hub or Hub 3.0 in Modem Only mode, it is essential that you are using a firewall on any device or router that is plugged directly into the Hub. When in Modem Only mode, your Hub does not operate with a firewall. If this does not apply to you, please proceed to the next step.
DMZ - Most firewalls, including the one provided with the Virgin Media Super Hub and Hub 3.0 include a DMZ option. This feature allows for a device using a specific local IP address on your home network (e.g. 192.168.0.2) to bypass your Firewall settings. This is occasionally necessary if you are using a device that has its own firewall configured. If you have a device configured in your firewall's DMZ that does not use its own firewall, it is crucial that you disable this option immediately. Computers operating without a firewall are extremely vulnerable to attack as all ports are essentially exposed to the wider Internet.
To check if a device is configured in the DMZ on your Virgin Media Hub 3.0:
  • Select the DMZ option
  • To remove a device from the DMS, tick the Disable box
To check if a device is configured in the DMZ on your Virgin Media Super Hub 1 or 2:
  • Select DMZ
  • To remove a device from the DMZ, uncheck the tick box at the top of the page
Where can I find further information and advice?
If you’d like further advice then our forum community will be happy to help. Just visit virginmedia.com/community and join the conversation on our Security Matters board.
You can find general security advice and articles on other vulnerabilities by checking Security Hub at virginmedia.com/securityhub
*Links to external sites are provided as a courtesy and virgin media is not responsible for the content of these sites or any issues encountered as a result of  applying information from these sites. Virgin media are not able to provide any technical support for such problems.
**Note: This article is intended to provide advice. Virgin Media is not responsible for any issues encountered in the course of resolving the issue and is not able to provide any technical support for such problems.
Need more help
    Ask our community
  • Helpful, friendly forums
  • Packed with tips and advice
  • Staffed by Virgin Media
    Contact us
  • Get in touch with our friendly team
  • Waiting times may vary
  • Free from Virgin Media phones or mobile
