How to use a pin to add a WPS client to your Hub
Click your Virgin Media Hub below for information on how the WPS feature works.
Hub 3
The Hub 3 has simple and straightforward setup procedure. The Hub 3 broadcasts its network name (SSID), and WiFi-enabled devices can pick up the Hub 3's signal and establish a connection to the network, as long as the correct WiFi network password is entered.
For the vast majority of users, the above setup process is by far the easiest way to create a WiFi connection.
An alternative method for setting up the WiFi connection is to use the Hub 3 Pair WPS feature.
WPS allows you to make a WiFi connection to the Hub 3 without needing to know the network name or password.
Advantages and disadvantages of using WPS
Advantages
  • WPS automatically configures the network name (SSID) and WPA security key for the Hub 3 and for WiFi devices that join the network
  • You do not need to know the network name and security keys or passwords to use WPS to join a WiFi network
  • No one can guess your security keys or passphrase because they are randomly generated
  • WPS uses the Extensible Authentication Protocol (EAP), which is a strong authentication protocol used in WPA2
Disadvantages
  • This technology is fairly new, so not all WiFi equipment supports WPS
  • Ad-Hoc mode does not support WPS. Ad-hoc mode is used when WiFi devices communicate directly to each other without an access point
Considerations before using WPS
In order for WPS to work well, all of the devices that you plan to connect wirelessly to the Hub 3 must support both the WPS and the WPA (Wi-Fi Protected Access) standards.
If some of your devices are not compatible with WPS, they will need to be connected to your WiFi network first using the standard setup procedure.
Mobile/Desktop only wrapper - from Medium breakpoint - to No limit breakpoint
Super Hub 2ac
The Super Hub 2ac has simple and straightforward setup procedure. The Super Hub broadcasts its network name (SSID), and WiFi-enabled devices can pick up the Super Hub's signal and establish a connection to the network, as long as the correct network security key (Passphrase) is entered.
Advantages and disadvantages of using Push 'N' Connect
Advantages
  • WPS automatically configures the network name (SSID) and WPA security key for the Super Hub and for WiFi devices that join the network
  • You do not need to know the network name and security keys or passphrases to use WPS to join a WiFi network
Disadvantages
Considerations before using Push 'N' Connect
In order for Push 'N' Connect to work well, all of the devices that you plan to connect wirelessly to the Super Hub must support both the WPS and the WPA (Wi-Fi Protected Access) standards.
After all of the non-WPS-compatible devices have been connected, any remaining WPS-compatible devices can then be connected via one of the Push 'N' Connect techniques covered in the below articles.
There are a couple of other ways to establish a connection via Push 'N' Connect. Please see the following guides for detailed instructions.
Using a PIN to add a WPS client to your Virgin Media Hub
Super Hub 2
The Super Hub 2 has simple and straightforward setup procedure. The Super Hub broadcasts its network name (SSID), and WiFi-enabled devices can pick up the Super Hub's signal and establish a connection to the network, as long as the correct network security key (Passphrase) is entered.
Advantages
Disadvantages
Super Hub
The Virgin Media Super Hub has a simple and straightforward setup procedure.
An alternative method for setting up the WiFi connection is to use the Super Hub's Push 'N' Connect feature, which is NETGEAR's implementation of the Wi-Fi Protected Setup (WPS) standard.
Push 'N' Connect allows you to make a WiFi connection to the Super Hub without needing to know the Super Hub's network name or network security key.
Advantages
Disadvantages
Other ways to get help
    Service status
  • Run tests on your services
  • Check for network outages
  • Book an engineer
     Check service status
    Help
  • Find help articles
  • Step-by-step guides
  • Watch help videos
     Get help
    My Virgin Media
  • Make a payment
  • Track your orders
  • Check service status
    Sign in
    Community
  • Helpful, friendly forums
  • Tips, help and advice
  • Staffed by Virgin Media
     Ask the community
