How Data Rollover Works
Mobile/Desktop only wrapper - from Extra small breakpoint - to Medium breakpoint
Your Account - view your bills,
check your recent usage, and
manage all of your services such
as roaming and call bars.
Your Account
Mobile/Desktop only wrapper - from Medium breakpoint - to Large breakpoint
Your Account
Your Account - view your bills, check your recent usage, and manage all of your services such as roaming and call bars.
Mobile/Desktop only wrapper - from Large breakpoint - to No limit breakpoint
Your Account
What is Data Rollover?
With Data Rollover, you won't lose unused inclusive data you've paid for when your monthly allowances refresh. Instead, you'll pocket this unused data to use next month.
Can I rollover data on any plan?
Yes you can. And what’s more, there’s no limit to the amount of data you can carry over from your data allowance. You will only rollover your basic regular data – not any promotional data.
Will my rolled over data accumulate month on month?
Any unused rollover data expires at the end of the month. It rolls over for one month only.
If there was a double data promotion when I purchased my plan, will I rollover the doubled amount or just the ‘regular’ amount?
When I change to a new plan, will my data rollover amount start again?
It will, and you’ll retain any leftover data from your previous plan. So if you have 1GB remaining, and you move down to a new plan, you keep that remaining 1GB and can use it on your new plan.
If I cancel my 30 day contract, will I still have data on day 31?
Rollover is only available while there is an active plan. If it is cancelled your data rollover will be removed too.
If I upgrade to a new phone on a Freestyle Contract from a SIM Only plan, will my data still rollover?
Yes, you will still rollover your data.
Will my data be rounded up or down when it rolls over?
Up! The data rollover feature will be applied in bandings, depending on the quantity of data that you roll over that month. So if you have 23MB left, you may rollover 25MB.
What will I see on my bill?
Any data usage will appear as normal on your bill, you will also see your Data Rollover allowance next to your Minutes, Text and Data allowances.
How will I know how much data I have rolled over?
You can see how much data you’ve saved for next month in the Virgin Mobile app. We’ll tell you when we've refreshed your allowances. We'll then text you when you've finished with your rolled-over data and started using your usual data allowance.
Other ways to get help
    Service status
  • Run tests on your kit
  • Identify network outages
  • Book an engineer
     Check service status
   Guided support
  • Browse help articles
  • Easy to follow videos
  • Step by step guides
     Get help
    My Virgin Media
  • Make a payment
  • Track your orders
  • Check service status
    Sign in
    Mobile Your Account
  • View mobile bills
  • Change your plan
  • Check balance
     Mobile Sign in
