  • Help
  • How do I save contacts to my mobile phone
How do I save contacts to my mobile phone?
Saving contacts to your phone rather than your SIM card means that you won’t lose them if you change your SIM.
See how below:
If you have an iPhone, contacts are automatically saved to your phone rather than your SIM card so you won’t need to do anything to save them to your phone before swapping your SIM.
To save your contacts to your android phone rather than your SIM card, just go to:
Contacts - Menu - Import/Export - From SIM to Phone.
The path may vary slightly depending on your handset make and model. For more details, check out Virgin Mobile phone support. Just select your handset from the main menu and click on contacts from the list of topics. We’ve used the Samsung Galaxy S8 as an example below.
You can also refer to the manufacturers guide that you would have received with your handset.
To save contacts to your Windows phone rather than your SIM card, just follow the instructions below:
1. Tap People then tap Menu at the bottom (three dots)
2. Tap Settings - Import from SIM
3. Pick the contacts you want to move then tap import.
 For more details, check out Virgin Mobile phone support. Just select your handset from the main menu and click on contacts from the list of options. We’ve used the Microsoft Lumia 650 as an example below.
Voicemail
Once you swap your SIM card, you will no longer be able to access any previously saved voicemail massages, so make sure to note down any important information you want to keep as it will be deleted when you swap.
Other ways to get help
    Service status
  • Run tests on your kit
  • Identify network outages
  • Book an engineer
     Check service status
   Guided support
  • Browse help articles
  • Easy to follow videos
  • Step by step guides
     Get help
    My Virgin Media
  • Make a payment
  • Track your orders
  • Check service status
    Sign in
    Virgin Mobile Account
  • View mobile bills
  • Change your plan
  • Check balance
     Sign in
