  • Help
  • What is my Virgin Mobile SIM Unlock PIN
What is my Virgin Mobile SIM's unlock PIN?
Every Virgin Mobile SIM card comes with a SIM unlock PIN already set. So once you insert your brand new 4G SIM, you’ll just need to enter 7890 when you switch on your phone.
Don’t worry if you forget the PIN.
The details below will be included in your brand new SIM pack.
If you’ve got a new iPhone, you’ll need to enter the SIM PIN as soon as you switch on your phone. If you’re just using a new SIM in your iPhone, then you’ll enter the SIM unlock PIN after you’ve entered your passcode or fingerprint.
If you’ve got an Android phone, you’ll enter the SIM unlock PIN as soon as you switch your phone on.
You’ll have three chances to enter the SIM unlock Pin. If you enter the wrong PIN code into your Virgin Mobile three times, your SIM card will automatically lock. If this happens, you’ll be asked to enter your PUK code.  Your PUK code is displayed on the SIM card holder that came in your starter pack.
No problem, just login to Your Account to find your PUK code.
It is possible for you to change the SIM unlock PIN.
If you’ve got an iPhone, you can change it by going into Settings > Phone > SIM PIN > Change PIN.
If you’ve got an Android phone, please go into Settings >Security > Change PIN.
If you’ve got an iPhone, you should go into Settings > Phone > SIM PIN to update your SIM PIN settings.
If you’ve got an Android phone, you should go into Settings > Security to update your SIM PIN settings.
If your screen shows any of the following when you first put your Virgin Mobile SIM into your phone: 'blocked', 'barred', 'incorrect SIM' or 'SP lock', your mobile may be locked to another network. There are a number of ways to unlock your phone, for help on this just text us for free on 07533 016 422^ and one of our team will be happy to help during our opening times 7am and 11pm Monday to Friday, 8am and 8pm Saturday to Sunday.
^The text is free for Virgin Mobile customers, or will be charged at your mobile provider’s standard rates.
Other ways to get help
    Service status
  • Run tests on your kit
  • Identify network outages
  • Book an engineer
     Check service status
   Guided support
  • Browse help articles
  • Easy to follow videos
  • Step by step guides
     Get help
    My Virgin Media
  • Make a payment
  • Track your orders
  • Check service status
    Sign in
    Virgin Mobile Account
  • View mobile bills
  • Change your plan
  • Check balance
     Sign in
