  • Help
  • How do I turn on roaming with Virgin Mobile
How do I turn on roaming with Virgin Mobile?
If you want to use your phone when you’re abroad, you’ll need to turn roaming on. Also, if you want to make calls abroad, you’ll need to make sure international call barring is turned off.
Follow these simple steps
Mobile/Desktop only wrapper - from Extra small breakpoint - to Small breakpoint
Swipe through
1
Sign in to Your Account
2
Select the Plans and devices tab at the top of the page.
3
Select Manage services tab
4
Make sure you turn roaming on under the Going abroad section
5
Finally check that the international call barring is turned off under the Call barring section
When you get back home
You should be automatically reconnected to our network when you return to this country after your visit.
If you’re struggling to reconnect, try these three things to give your phone a helping hand.
Swipe through
1
Turn your phone off and on
2
Select the network manually from your phone’s settings
3
If you can, try removing your phone’s battery while it’s switched on, this helps reboot it and find a local network. If it’s a sealed unit follow the restart option
Other ways to get help
    Service status
  • Run tests on your kit
  • Identify network outages
  • Book an engineer
     Check service status
   Guided support
  • Browse help articles
  • Easy to follow videos
  • Step by step guides
     Get help
    My Virgin Media
  • Make a payment
  • Track your orders
  • Check service status
    Sign in
    Virgin Mobile Account
  • View mobile bills
  • Change your plan
  • Check balance
     Sign in
