How do I use Virgin Mobile Voicemail?
Activating Your Voicemail
Your voicemail should automatically activate as soon as you switch on your new phone. If this hasn’t happened, don’t worry, you can switch it on manually by following these simple steps:
Swipe through
Sign in to Your Account
Select Plan and device
Select Manage services
Select option to turn on voicemail
If that doesn’t do the trick, you can also:
- Dial 222 from your mobile and listen to the message until the end
- Keep your phone on for 20 minutes. If you get a text that says PERS, ignore it
- After 20 minutes, turn your phone off and on again
Voicemail Features
When you activate your Voicemail you will have different features depending on whether you have a Pay Monthly plan or Pay As You Go plan. You can see the difference between our Voicemail features below:
Voicemail Type | Standard |
Plus |
Total Number of Messages (per mailbox) | 10 |
30 |
Message Length (seconds) | 90 | 180 |
Days kept un-played (with auto-discard) | 3 | 21 |
Days kept Played (with auto-discard) | 3 | 21 |
If you have a Pay Monthly plan, you'll automatically be set up on Voicemail Plus.
If you have a Pay As You Go plan you'll be set up on Voicemail Standard, but you can upgrade to Voicemail Plus for a one time £5 fee. To upgrade to Voicemail Plus, just text us for free on 07533 016 422^ and one of our team will be happy to help during our opening times 7am and 11pm Monday to Friday, 8am and 8pm Saturday to Sunday.
Now your voicemail’s set up. If you need any further help, select an option below.
Your voicemail already comes with a standard greeting, but it's a good idea to record one of your own – that lets people know they've dialled the right number.
Here's how:
- Call your voicemail (usually this means holding down the 1 key on your phone or dial 222 from your handset)
- Choose option 2 from the first menu (Greetings) and follow the instructions from there
A PIN number will protect your voicemail and lets you pick up your messages from any touch tone phone.
Here's how to set your PIN
- Call your voicemail (usually this means holding down the ’1’ key on your phone or dial 222 from your handset)
- Choose option 3 from the first menu (settings & features) and follow the instructions from there
Your PIN
- Must be from 4 to 10 digits long
- Can't be a single digit repeated (like 1111)
- Can't be an ascending or descending sequence (like 1234 or 7654)
- Can't be your phone number or part of it
- Can't be 7890, 2580 or 1210
- Can't be the same as a previous PIN
To access voicemail from your mobile phone
- If you're not sure which button to press, check out our Virgin Mobile Phone Support
- If you’ve set a PIN you’ll be prompted to enter your PIN
To access your voicemail from another phone
- Call your Virgin Mobile number from another phone and let it go to voicemail
- Interrupt your voicemail greeting by pressing *
- Enter your voicemail PIN
- You'll then be able to access your voicemail as if you were dialling it from your mobile
There's a really quick and easy way to extend the amount of time your phone rings for before voicemail kicks in.
Here's how to update your ring time:
If you’ve not had a new SIM since December 2017
To extend the ring time to 30 seconds, first enter this code into your phone: **61*+447953222222**30#. Next, press the call or answer key - your phone will do the rest.
If you’ve had a new SIM since December 2017
To extend the ring time to 30 seconds, first enter this code into your phone: **61*+447458333222*11*30#. Next, press the call or answer key - your phone will do the rest.
You can alter this to ring for 5, 10, 15, 20 or 25 seconds by replacing **30# with your choice of seconds. E.g. enter **15# if you want it to ring for 15 seconds. The most you can extend it to is 30 seconds.
Message alerts are free text messages that are sent to your phone whenever you are left a voicemail, but you can choose whether you receive these message alerts.
This won’t change the voicemail indicator if your phone supports this.
To change your voicemail alerts:
- Select option 3 from the main menu, you will be given 5 options, press 2
- The recorded message will tell you if your alerts are on or off, if you would like to change the status of your alerts press 1
- You will then need to press 1 again to change the staus
You can do this whenever you want to change the status of your message alerts.
Voicemail diverts will send your calls to voicemail in certain situations, like when your phone is switched off. To adjust these on your phone see our Virgin Mobile Phone Support.
If you get stuck along the way, just text us your problem for free on 07533 016 422 ^ between 7am and 11pm Monday to Friday, 8am and 8pm Saturday to Sunday, and one of our team will be happy to help.
A voicemail box number is the number your phone dials when you access your voicemail. It’s usually stored in your phone so that you can call simply by pressing the number 1 key.
If you need the full voicemail number, if you've had a new SIM since December 2017, dial +447458333222.
If you joined us before December 2017 and haven't changed your SIM dial +447953222222.
Once you’ve entered this number into your phone's voicemail setting, you’ll be to access your messages by pressing ‘1’ on your keypad for a couple of seconds, or you can save the number to your phonebook and dial it from there.
If you get stuck along the way, just text us your problem for free on 07533 016 422 ^ and one of our team will be happy to help during our opening times 7am and 11pm Monday to Friday, 8am and 8pm Saturday to Sunday. Alternatively, you can call us on 789 from your Virgin mobile phone, or 0345 6000 789 ° from any other phone. Lines open 8am-9pm Monday to Friday, 8am-8pm Saturday, 8am-6pm Sunday. You can also check out our Virgin Mobile Phone Support for more info.
Other ways to get help
