blueGreenTwo.svgblueGreenOne.svgblueGreenThree.svg
Using the Virgin TV box
Understand how to use the Virgin TV box – including handy hints and tips to get the best out of it.
Which Virgin TV box and remote do you have?
Some of our TV boxes and their remotes look similar but work together differently, so double check what combination you have.
Not sure which TV box and remote you have? Let us help
imageAlt
360
imageAlt
Stream
imageAlt
V6
imageAlt
TiVo
How to use the Virgin TV V6 box
Whether you’ve just set up the Virgin TV V6 box or had it for a while, it’s always good to have our guides on hand. Take a look at our video below to understand how to use the V6 box or download the full guide and read through our tips and tricks.
Download guide
FAQs
Has this helped?
How to use the Virgin TV 360 box
Whether you’ve just set up the Virgin TV 360 box or had it for a while, it’s always good to have our guides on hand. Take a look at our video below to understand how to use the 360 box or download the full guide and read through our tips and tricks.
Download guide
FAQs
Has this helped?
How to use Stream from Virgin Media
Whether you’ve just set up the Virgin TV Stream box or had it for a while, it’s always good to have our guides on hand. Take a look at our video below to understand how to use the Stream box or download the full guide and read through our tips and tricks.
Download guide
FAQs
Has this helped?
How to use the Virgin TV TiVo box
Whether you’ve just set up the Virgin TV TiVo box or had it for a while, it’s always good to have our guides on hand. Take a look at our video below to understand how to use the TiVo box or download the full guide and read through our tips and tricks.
Download guide
FAQs
Has this helped?
