  • Help
  • My 3G or 4G isn't working
Follow our top tips to get your 3G and 4G back up and running.
Tip 1
Check your mobile data setting is switched on – and not locked or in airplane mode
Tip 2
Make sure you are automatically connected to a network. If you have a 4G device in a 4G coverage area but are only able to connect to 3G, double check 4G is switched on
Tip 3
Restart your device to refresh your network connection
Tip 4
Run a check on the network in your area with our coverage checker
Need more help?
  • Try your SIM in another device to see if the issue is with the handset
  • If you have recently swapped to a new SIM and are looking for the APN Settings (Access Point Name), please send a text message with the word ALL to 789922. You’ll then receive a text message advising you to save these settings to the handset
Other ways to get help
    Service status
  • Run tests on your kit
  • Identify network outages
  • Book an engineer
     Check service status
   Guided support
  • Browse help articles
  • Easy to follow videos
  • Step by step guides
     Get help
    My Virgin Media
  • Make a payment
  • Track your orders
  • Check service status
    Sign in
    Virgin Mobile Account
  • View mobile bills
  • Change your plan
  • Check balance
     Sign in
