Getting your device online
From the home screen on you mobile tap Settings
Step 1
From the home screen tap Settings
Tap Wi-Fi
Step 2
Tap WiFi
Tap the Wi-Fi network you'd like to connect too
Step 3
Tap the WiFi network you'd like to connect to, your WiFi network name and password are shown on the bottom of the Hub.
Enter the network password, then tap Join
Step 4
Enter the network password, then tap Join.
Has this solved your issue?
