Mobile/Desktop only wrapper - from Medium breakpoint - to No limit breakpoint
The Hub is off
  • Make sure the Hub's power supply is firmly connected to the wall and back of the Hub, check the Hub is switched on
  •  It can take 5 to 10 minutes for the Hub to reboot
  • Once the white power light is solidly lit you’re good to go
Are you able to get online now?
There is a small switch at the back of your hub. Make sure it's switched on. The plug from the hub connected to the mains power and switched on
Mobile/Desktop only wrapper - from Extra small breakpoint - to Medium breakpoint
The Hub is off
