  • Help
  • Hub Connection Status
How do I check the advanced connection status of the Hub?
What Hub do you have?
Hub 3 or Hub 4
Mobile/Desktop only wrapper - from Medium breakpoint - to No limit breakpoint
How to check the connection status of the Hub 3 or Hub 4
Step 1 icon
Enter 192.168.0.1 into the address bar of your browser, the settings page will then load
Step 2 icon
Under Modem status overview you can see the status of your modem and the devices that are currently connected
What devices are connected to the Hub? For a more detailed look at what devices are connected, select connected devices on the left.
Looking for more information?
Modem device information
To see more details about the Hub, select Admin and then Info, here you can see hardware and software versions and how long it has been turned on and connected to the Virgin Media network
Network status information
To see more details about the Hub’s connection to the Virgin Media network, select on Advanced settings, Tools and then Network status, here you can see further details about the Downstream, Upstream, Configuration and Network logs
Super Hub 1, 2 or 2ac
How to check the connection status of the Super Hub
Step 1 icon
Step 2 icon
Select Device Connection Status
The following screen will show information about the Super Hub's connection status, including useful details about any devices that are currently connected to the Super Hub
If you'd like even more information about the Super Hub's connection status, do the following:
Mobile/Desktop only wrapper - from Extra small breakpoint - to Small breakpoint
Swipe through
Step 1 icon
Return to the Super Hub's main settings page and select Advanced Settings
Step 2 icon
In the Device Management section, select Device Status*
Step 3 icon
Select Device Management at the top to return to the previous screen. Select Network Status to see more details about your Super Hub's connection to the Virgin Media network
*You will see more details about your Super Hub, such as hardware and software versions, how long it has been turned on and connected to the Virgin Media network. You can also view your Super Hub’s LAN and WAN IP details here.
Other ways to get help
    Service status
  • Run tests on your kit
  • Identify network outages
  • Book an engineer
     Check service status
   Guided support
  • Browse help articles
  • Easy to follow videos
  • Step by step guides
     Get help
    My Virgin Media
  • Make a payment
  • Track your orders
  • Check service status
    Sign in
    Virgin Mobile Account
  • View mobile bills
  • Change your plan
  • Check balance
     Sign in
