  • Help
  • My Virgin Media WiFi connection is intermittent
Having WiFi troubles? Run tests on your services, check for faults in your area and more... Sign in
Mobile/Desktop only wrapper - from Extra small breakpoint - to Small breakpoint
Mobile/Desktop only wrapper - from Small breakpoint - to Large breakpoint
is intermittent
Mobile/Desktop only wrapper - from Large breakpoint - to No limit breakpoint
is intermittent
Follow our step-by-step guide to get back online. If that doesn't work we'll put you in touch with our team. Simple as that.
Are any lights shown on the Hub?
Tip 1
Find the best place for the Hub making sure it’s kept out in the open and in the upright position
Tip 2
Reboot the Hub by turning it on and off again
Tip 3
Check each device, if one of your devices is suffering slow speeds whilst the others are working fine, there could be a limitation with it
Tip 4
Get rid of blackspots, if you have a Hub 3 why not download the Virgin Media Connect app to scan your home for WiFi blackspots
Tip 5
Visit our Service status page to run a test against your kit and to check for network outages.
