  • Help
  • No Wifi Connection Hub 4
What lights are you seeing?
The light ring is an easy way to see what the Hub 4's up to. If there is a problem it will tell you what is going on.
Solid white light
Solid white light
Dimmed white light
Dimmed white light
Blue light
Blue light
Red light
Red light
Green light
Green light
Flashing white light
