The Hub is on
  • When you push the WPS button on the back of the Hub the light ring will flash blue slowly for 2 minutes.
  • When a WPS connection has been successful the light ring will turn solid blue for 20 seconds.
If the light ring flashes blue rapidly it means the WPS connection was unsuccessful and you should try again.
