Having TV troubles? Run tests on your kit, check for faults in your area and more...Sign in
How do I fix audio and video problems on my Virgin TV?
Just answer a few simple questions so we can get you back up and running in no time.
Let us know what sort of issue you’re having
Having some problems with your Virgin TV box? Don’t worry, we’re here to help.
First, please check our Service status page for up to the minute information on known issues in your area.
To keep an eye on how your TV services are working when you’re on the move, just download our handy My Virgin Media app onto a compatible iPhone or Android mobile handset.
Virgin TV V6, powered by TiVo
First, check that the Video Output Settings on your Virgin TV V6 box are set to a format your TV supports – normally either; 720p, 1080i or 2160p.
To do this
  1. Press Home on the remote
  2. Select Help & Settings
  3. Select Settings
  4. Select Video Output
  5. Select Video Output Format
  6. Select Change settings
  7. Select Auto Detect
The Video Output Format screen allows you to test and set the video output format manually.
Select Test Formats and then follow the on-screen prompts to test which formats your television can display.
The supported formats will be automatically selected in the list of available video formats.
You might want to experiment with all the different video formats that your TV and Virgin TV V6 box support.
You may find that some formats are better suited to certain shows than others.
If this hasn’t helped, or you don’t have a picture, check below for more help.
If you've just switched on your TV and have no picture, and there’s a red light on the right of your V6 box then your Virgin TV V6 box is in standby. This may happen automatically after four hours. For more details on Virgin TV V6 standby options, or if you want to change them see Standby Settings on your Virgin TV box
So, first thing is to wake up your Virgin TV V6 box. It’s easy to do, just press any of the buttons below on your Virgin TV V6 remote:
  • Home
  • TV
  • Channel Up / Down
  • Any number key
  • Standby / Power
If you don’t have a TV picture after this then make sure that the TV is set to the correct input.
NOTE: The AV button can be marked AV, Source or Input on the remote, or can sometimes be shown as a circle or square with an arrow through it.
If this doesn’t work there may be a connection or lead problem, does your Virgin TV V6 remote control LED light up when you change channel using the Channel Up / Down buttons on the remote?
  • If not, check the batteries fully charged and inserted as shown on the diagram in the battery compartment.
  • If so, check the HDMI lead between the box and the TV is connected securely
If your problem is still not resolved then restart your V6 box.
If you see the message ‘HDMI connection not permitted, press OK for more information’ or your picture keeps freezing or blanking, there are a few things you can try to fix this.
Try each of the following steps in this order and check after each to see if you are able to view normally:
  • Check to see if any of the cables at the back of your V6 or TV have come loose. If they have, push them securely into their connections
  • Try disconnecting and reconnecting the HDMI cable from the TV to the Virgin TV V6 box. It sounds odd, but often works!
  • Press Channel Up and Channel Down on your Virgin TV V6 remote
  • With the TV on, switch the Virgin TV V6 box in and out of Standby
These bars may have been added by the TV channel broadcaster, your set top box or TV. To make sure it's not a Virgin TV V6 setting you'll need to check two of the settings.
Check the Aspect Correction mode.
  3. Select Settings
  5. Select Aspect Correction Mode
We normally recommend setting this is set to Panel as this makes sure that all programmes are shown by Virgin TV V6 without any alteration.
When you’re watching older programmes on SD channels you may find that there are bars down the left and right of the screen. If you change the Aspect Correction Mode to Full Screen or Zoom the picture is altered to fill the TV screen.
If you’re watching an older programme on an HD channel, you won’t be able to remove the bars, as these are part of the picture received from the broadcaster.
If you can’t make the changes you wish, check your TV’s manual for further picture options.
Try changing channels, then switch back again.
  • Press Back or Last Ch on the remote to try and re-sync
  • Go to the Home screen, then press TV to go back to live TV
  • Check that all your cable connections are plugged in properly
If your problem is still not resolved then restart your Virgin TV V6 box.
TiVo
First, if you’re connecting to a HDTV, check that the Video Output Settings on your TiVo box are set to a format your TV supports – normally either 720p or 1080i.
To do this
  3. Select Settings
  6. Select Auto Detect
You might want to experiment with all the different video formats that your TV and TiVo support.
If you've just switched on your TV and have no picture, and there’s a red light on the left of your TiVo box then your TiVo box is in standby. This may happen automatically after four hours. For more details on TiVo’s standby options, or if you want to change them see Standby Settings on your Virgin TV box.
So, first thing is to wake up your TiVo box. It’s easy to do, just press any of the buttons below on your TiVo remote:
  • Home
  • TV
  • Channel Up / Down
  • Any number key
  • Standby / Power
If this doesn’t work there may be a connection or lead problem, does your TiVo Remote Control LED light up when you change channel using the Channel Up / Down buttons on the remote? Does a corresponding light appear on the front of the TiVo box when you press a button?
  • If so, check the SCART/HDMI lead between the box and the TV is connected securely
If your problem is still not resolved then restart your TiVo box.
  • Check to see if any of the cables at the back of your TiVo or TV have come loose. If they have, push them securely into their connections
  • Try disconnecting and reconnecting the HDMI or SCART cable from the TV to the TiVo box. It sounds odd, but often works!
  • Press Channel Up and Channel Down on your TiVo remote
  • With the TV on, switch the TiVo box in and out of Standby
These bars may have been added by the TV channel broadcaster, your set top box or TV. To make sure it's not a TiVo setting you'll need to check two of the settings.
First check the TV Aspect Ratio is set correctly.
  3. Select Settings
  4. Select Video
  5. Select TV Aspect Ratio
  6. Select your TV type
Next check the Aspect Correction mode
We normally recommend setting this is set to Panel as this makes sure that all programmes are shown by TiVo without any alteration.
Other ways to get help
    Service status
  • Run tests on your services
  • Check for network outages
  • Book an engineer
     Check service status
    Help
  • Find help articles
  • Step-by-step guides
  • Watch help videos
     Get help
    My Virgin Media
  • Make a payment
  • Track your orders
  • Check service status
    Sign in
    Community
  • Helpful, friendly forums
  • Tips, help and advice
  • Staffed by Virgin Media
     Ask the community
