Do you need a landline for broadband?
Some types of broadband still need a copper phone line to get you connected, but that doesn't mean you have to pay for a landline if you don't want one. Here’s everything you need to know
By Virgin Media Edit
- Published
- 17 April 2026
No, you don’t always need a landline for broadband. Many packages are broadband-only, especially if you’re choosing newer technologies like full fibre or 4G/5G home broadband, which don’t rely on a traditional phone line.
You may still need a physical phone line connected to your home to get broadband with some providers. That’s because some UK providers use older fibre-to-the-cabinet (FTTC) or ADSL connections that rely on copper phone wires to get you connected, so you need to have a phone line to your home to get their broadband.
Even then, you don’t always need to pay for a phone service; just the line itself.
With newer full fibre connections and with Virgin Media fibre, you don’t need to have a phone line at all. That’s because these connections either bypass the street cabinet to bring the connection directly to your home or use coaxial cables instead of phone lines to connect you to the internet.
If you don’t use a home phone, it’s a good idea to look for broadband only deals that don’t include or require a landline so that you can save money.
Types of broadband that don't need a landline
Not all broadband relies on a traditional phone line or the old copper network. These types of connections work without a traditional landline:
Full Fibre is also the fastest and most reliable broadband type available. It uses fibre optic cables all the way to your home, so no copper phone line is needed. Because it’s a 100% fibre connection, it does not use the old copper phone network. That means you don’t need a landline.
4G/5G Home Broadband uses a mobile signal to connect your home router, so there’s no need for any physical line. A router in your home connects to a mobile network, delivering internet through WiFi without installing a landline or broadband line. As it’s completely wireless, no landline is required.
SOGEA (Single Order Generic Ethernet Access) broadband is a connection that doesn’t require a traditional landline, even though it still uses some of the copper cables as in FTTC broadband. Broadband runs over the existing network without needing a separate phone line. While SOGEA removes the need for a landline, it still relies partly on copper cables, so newer technologies like full fibre or fibre broadband can offer faster and more reliable performance.
Which types of broadband need a copper phone line?
Some types of broadband that need a copper phone line to work. These types use the same cables as a traditional landline phone, so a phone line is required:
ADSL is one of the oldest types of broadband. It uses the copper phone line in your home to connect you to the internet. Because it relies on this line, you’ll need to have a landline and usually pay for line rental. ADSL can sometimes be the only option in rural or remote areas, but it's also the slowest type of broadband.
VDSL (Very-high-bit-rate Digital Subscriber Line) is a type of internet connection that uses copper telephone wires to deliver high-speed internet. It’s an improved version of DSL technologies like ADSL, but uses the same phone copper wires to transmitting data and connect you to the internet.
FTTC is a type of fibre broadband that uses fibre optic cables to connect from the telephone exchange to a street cabinet, but still uses copper phone lines from the cabinet to your home. This means you still need landline, so line rental is usually included in the broadband package.
Do you need a phone line to get Virgin Media broadband?
No, you don’t need a landline or a phone line to get Virgin Media broadband. Our broadband service runs through our own fibre network, which uses coaxial cables rather than a phone line to get you connected. That means we can bring fast and reliable internet straight to your home without the need for a landline connection.
You can still add TV or a home phone service if you like, but you don’t need to if you don’t want to. We’ve designed our packages to be flexible, so you can pick what works best for you, and if you just want broadband on its own, that’s absolutely fine with us.
Looking for broadband without a home phone? Check out all of our broadband deals without a landline to get broadband without a landline attached.
Is it cheaper to get broadband without a landline?
Broadband without a landline can sometimes be cheaper, but it depends on the provider and the type of broadband you choose. If you don’t use a home phone, it makes sense to look for broadband deals that don’t include a landline so you’re not paying for something you don’t need.
However, some providers still use phone lines to deliver broadband, so even if you don’t use the phone, you might still have to pay for line rental. In those cases, the cost of the landline is built into the price of the broadband package, and it may not be any cheaper to go without it.
If you choose a provider that offers broadband through cable or full fibre (like Virgin Media), you can get broadband without a landline and save money by not paying for a line rental or phone service.
Do I still need to pay for line rental if I don't have a landline??
You’ll only have to pay for the line rental if your provider uses copper phone wires to connect you to the internet. Even then, the cost is usually just part of the overall price you pay for a broadband service, and you most likely won’t be charged extra to keep the connection running.
To avoid paying for a line rental entirely, it’s worth looking for a broadband provider that doesn’t use a phone line connect you to the internet. That includes fibre options like Virgin Media fibre since we don’t need a landline to get you connected.
Do I still need a landline with Digital Voice?
The UK is switching off traditional copper landlines to ensure they're fit for the future. This means home phone services are moving to Digital Voice, replacing the old copper phone lines and using a broadband connection instead.
This means:
You no longer need a traditional copper phone line for home phone services.
Your phone will connect via an adapter to your broadband Hub instead of the old wall socket.
If your home experiences a power cut, your digital landline won’t work unless you have a battery backup – so keeping a mobile phone handy is a good idea.
If you rely on a landline or use telecare equipment, your provider will offer the necessary support to ensure you remain connected.
Can I get broadband if I don't have a phone line connection?
You can still get broadband even if you don’t have a phone line, but you’ll need to either request to get a phone line hooked up to your home or choose a broadband provider that doesn’t use a phone line to connect you to the internet.
Openreach has a Universal Service Obligation for broadband and phones, so if your home doesn’t have a line connected, you should be able to check if you’re eligible and request one. You can do this through Openreach directly.
If you don’t have a phone line and don’t want one, look for broadband only deals that don’t require a phone line. These packages are made for people who just want internet without paying for a landline or home phone service.
Broadband deals without a landline or phone line
At Virgin Media, all our broadband deals come without a landline by default. That means you can get our superfast fibre broadband, TV and SIM deals all without a landline if you don’t want one.
Be sure to check out our broadband without landline deals to find a broadband only package that works for you.
More broadband tips, tricks and stories
