Check the phone connections
  • To get the best connection connect your phone directly into the main Virgin Media wall socket and check you’re not using an extension cable
  • Check the connection is tightly connected, it makes a 'click' noise when connected properly
Are you getting a dial tone on all your home phones now?
If your phone is connected into the Hub click here
