  • Help
  • Parental Controls TV Pin
What is my Virgin Media TV parental control PIN?
When you have Virgin TV you also have a PIN. This is used for Parental Control and when you purchase On Demand shows or Live Events.
Which one do you have?
Virgin TV V6 Box
Your default PIN is 1234 and if your box is replaced for any reason your PIN will reset to this.
It’s important that you keep your PIN number safe and don’t give it to any younger children.
To find out how to use your PIN see Parental controls on Virgin TV.
Change your PIN
To change your PIN from the default or if you think it’s been discovered:
1
Press Home on the remote
2
Select Help & Settings
3
Select Parental Controls then enter your current PIN
4
Select Change PIN and follow the on screen instructions
Forgotten your PIN
If you can’t remember your PIN, try 1234 first. If this doesn’t work, you can reset your PIN.
1
2
3
Select Help, then select TV Care
4
Select Reset my PIN
Virgin TV TiVo Box
If you use apps on TiVo such as Netflix or BBC iPlayer, they may have their own PIN or Parental Control set.
See Parental control for Apps on Virgin TV for more.
Setting your PIN
It's a good idea to change the PIN as soon as your box is set up. On your TiVo box a PIN is always needed to watch:
  • Programmes rated 12, before 8pm
  • Programmes rated 15, before 9pm
  • Programmes rated 18, before 10pm
  • A channel you’ve chosen to lock
  • A channel which is locked as it has shows rated PG-18 airing pre 9pm.
  • Any adult channels
On Demand content carries either an age rating (such as PG, 15 or 18) or a ‘G’ for ‘Guidance’ as used by some broadcasters. All our On Demand programmes and movies carry a synopsis containing the Guidance information.
Change your PIN
To change the PIN from the default or if you think it’s been discovered:
1
2
3
4
Forgotten your PIN
1
2
3
4
Select Reset my PIN
Note: This will reset your PIN on all your Virgin TV boxes.
Other ways to get help
    Service status
  • Run tests on your kit
  • Identify network outages
  • Book an engineer
     Check service status
   Guided support
  • Browse help articles
  • Easy to follow videos
  • Step by step guides
     Get help
    My Virgin Media
  • Make a payment
  • Track your orders
  • Check service status
    Sign in
    Virgin Mobile Account
  • View mobile bills
  • Change your plan
  • Check balance
     Sign in
