Check your Hubs connections
Here are some simple steps to follow to check your connections
Step 1
Make sure the Hub's power supply is firmly connected between the wall and the Hub, and make sure the power is switched on.
Step 2
Make sure the white cable is tightly connected into the Virgin Media wall socket.
Click on your WiFi network name, check the Connect automaitcally box and then click Connect.
Step 3
From the wall socket follow the cable making sure it's tightly connected to the splitter and the back of the Hub.
Are you able to get online now?
