How much data does streaming use?
Ever wondered how much data you munch through when streaming films, box sets or live matches? The answer depends on what you watch and how sharp you like your picture
By Virgin Media Edit
- Published
- 20 March 2026
Streaming has quietly become the background soundtrack to our daily lives. There’s always something playing somewhere. A comfort sitcom looping while you cook dinner. A live football match lighting up the living room. A nature documentary running in the background while someone scrolls their phone.
But behind that simplicity sits a constant flow of internet data travelling between your home and the streaming service. Every film, series episode and live match uses data depending on its quality, length and how you’re watching.
Modern broadband connections are built to handle it. But understanding how much data streaming actually uses can help explain why connection speeds, WiFi performance and streaming quality matter more than you realise.
Streaming works by delivering video in small chunks rather than downloading the entire file at once, letting you start watching instantly. Higher video quality means more data per second, from SD to 4K.
For most homes with fixed broadband, streaming isn’t usually a problem. What matters more is broadband speed and WiFi performance, particularly if several people are streaming at the same time.
Here’s a rough guide to data usage per hour depending on video quality:
Standard definition (SD): around 1GB
High definition (HD) YouTube video: around 3GB
Full HD (1080p): 3–4GB
One 2-hour 4K film: 14-20GB
What affects how much data streaming uses
The exact amount of data used when you stream depends on several factors.
Video resolution
Streaming in 4K delivers stunning picture clarity, but it also uses significantly more data than HD or standard definition. Higher resolutions (1080, 4K) require much more data per hour (7-10GB) compared to standard definition (roughly 700MB-1GB).
The length of what you're watching
A short 25-minute sitcom episode uses far less data than a two-hour blockbuster film. It sounds obvious, but longer viewing sessions naturally increase the total amount of data being used.
The number of devices streaming at once
In busy households, several devices often use the internet at the same time. One person might be watching a series in the living room while someone else streams videos in their bedroom, while another device plays music or runs a video call in the background.
Each active stream uses its own share of bandwidth and data, which increases overall demand on your broadband connection. This is why faster broadband speeds help keep everything running smoothly.
Live sports and streaming events
Streaming live football matches, Formula 1 races or other major events can use similar amounts of data to regular HD or 4K streaming. An HD football match typically uses around 3GB per hour, while a 4K live stream may use 7–10GB per hour. Watching live sports can be more demanding when several people are watching while others may be gaming or browsing.
How can I use less data when streaming?
If you're using mobile data, tethering your phone or simply want to manage how much internet data your household uses, there are a few simple ways to reduce streaming data usage:
Most streaming apps allow you to switch from 4K or HD to standard definition. Lower resolutions use significantly less data while still delivering a good viewing experience on smaller screens.
Many streaming services allow you to download episodes or films while connected to WiFi. This means you can watch later without using additional data.
Multiple TVs, tablets and smartphones streaming simultaneously can quickly increase total data usage. Managing how many devices are active at the same time can help reduce overall demand on your connection. Learn how to connect multiple devices without slowing down your WiFi.
Some platforms automatically play the next episode or stream content in the background. Turning off autoplay can help limit unnecessary data usage.
Want unlimited data? Grab a broadband deal with Virgin Media
With Virgin Media’s unlimited broadband deals, you can stream, game, browse, and keep smart devices connected without worrying about data limits or throttling. Multiple streams, multiple devices, and even 4K films all run smoothly, so everyone in the household enjoys a reliable connection.
Not sure what speeds or packages are available where you live?
Take a look at our broadband deals and enter your postcode to see what Virgin Media services you can get at your address.
More broadband tips, tricks and stories
