How to hotspot on iPhone, Samsung, Google Pixel and more
Looking to share your phone’s 4G or 5G connection with another device? Setting up a hotspot lets you do just that. Here’s everything you need to know about hotspots and how to hotspot on your iPhone, Samsung, Google Pixel and more
By Virgin Media Edit
- Published
- 21 August 2025
What is a hotspot?
A personal hotspot is a feature on smartphones that lets you share your mobile 4G or 5G internet connection with your other devices. When you turn on your personal hotspot, your phone acts like a small WiFi router, and other devices can connect to it using WiFi, just like they would connect to your home internet.
Mobile hotspots are useful when you're in a place that doesn't have WiFi but your phone still has a 4G or 5G connection. You can connect your laptop or tablet to your phone’s hotspot to go online, allowing you to stay connected when there’s no WiFi available. Just keep in mind that using your hotspot uses up your phone’s data plan, and it can also make your battery drain faster.
How does a hotspot work?
A hotspot takes the internet signal from your phone’s mobile data and turns it into a WiFi signal that other devices can connect to. Your phone connects to the internet through a mobile network, and when you turn on the hotspot, your phone broadcasts a small wireless signal, just like your WiFi router does at home.
Other devices, like a laptop or tablet, can see this signal and connect to it using the password you set. Once connected, those devices use your phone’s data to access the internet, which will work as normal as long as your phone has a strong enough signal and enough data in your mobile plan.
The process might look something this:
Your phone gets mobile data – Your phone connects to the internet using your 4G or 5G, just like it does when you’re browsing or using apps.
You turn on the hotspot feature – You go into your phone’s settings and switch on the personal hotspot option.
Your phone creates a WiFi signal – Once the hotspot is on, your phone acts like a mini-Wi-Fi router and sends out a wireless signal.
Other devices connect to the signal – Laptops, tablets, or other phones nearby can find your phone’s signal and connect to it by entering the password you set.
They use your phone’s data to go online – Once connected, those devices use your phone’s mobile data to browse the internet, watch videos, or do anything else online.
What do I need to set up a hotspot?
For a hotspot to work properly, you need a few basic things in place. These make sure your phone can connect to the internet and share that connection with other devices.
Here’s what you’ll need:
Not all phones have a hotspot feature. Most modern smartphones do, but older models or basic phones might not. You can check your phone’s settings to see if there's an option for “Personal Hotspot” or “Mobile Hotspot.”
Keep in mind that some phones limit the number of devices that can connect to the hotspot at the same time. Most phones allow 5-10 devices to connect, but this depends on the phone model and your network provider’s restrictions.
A personal hotspot uses your phone’s mobile data to create a WiFi connection that other devices can use. That needs you’ll need must have an active mobile data plan for the hotspot to work. Without mobile data, your phone cannot access the internet, and you won’t be able to share it.
Some carriers also offer unlimited data plans that include hotspot use, while others have separate data allowances for hotspot usage. Be sure to check with your carrier if your plan supports hotspot use and whether it has any limits. Keep in mind that using a hotspot can consume a lot of data too, especially if you're streaming video or downloading large files.
For your hotspot to give a good internet connection, your phone needs a strong mobile signal usually 4G or 5G. If you’re in a place with poor reception, your hotspot will be slow or might not work at all. 5G offers faster speeds, but in areas where only 3G or 4G is available, your hotspot speed will be slower.
Using a hotspot drains your phone battery quickly because it keeps the internet and WiFi running at the same time. If you’re using the hotspot for extended periods, expect your phone’s battery to drop quickly. It’s a good idea to plug in your phone to a charger if you plan on using it for a while.
Some smartphones also allow you to adjust battery-saving features while the hotspot is active. For example, you can dim the screen or turn off unused apps to preserve battery life while using the hotspot.
The device you want to connect to your hotspot (like a laptop, tablet, or another phone) must be able to connect to WiFi for you to be able to use a hotspot. You connect to the hotspot over WiFi, and you should find your hotspot name's in the list of available WiFi networks in your settings once you've set the hotspot up.
How to hotspot
The way you turn on and use hotspot depends on the device you’re hotpspotting from. Whether you’re using an iPhone, Samsung, or another Android phone, the steps are straightforward and mostly involve turning on the hotspot feature in your phone’s settings.
On most phones, there’s a section in settings called "Personal Hotspot" or "Mobile Hotspot" where you can turn hotspot on and connect your devices to it. You’ll usually see network name and a password there that others will use to connect to.
Once the hotspot is on, you can go to the device you want to connect to it, like a laptop, and find the phone’s hotspot name in your WiFi settings.
To break down the process, here’s a step-to-step guide to hotspotting on multiple devices:
How to hotspot on iPhone (iOS)
Open the Settings app on your iPhone.
Tap Personal Hotspot (or go to Cellular > Personal Hotspot).
Toggle on Allow Others to Join.
You’ll see a Wi-Fi password. This is the password others need to connect.
On another device, look for your iPhone's name in the WiFi list and connect using that password.
The way you hotspot on iPhone can sometimes to slightly different depending on on which device you've got. Need an upgrade? Check out the latest iPhone deals.
Hot to hotspot on Samsung
Open the Settings app.
Tap Connections (or Network & Internet on some versions).
Select Mobile Hotspot and Tethering.
Tap Mobile Hotspot and toggle it on.
You can tap Mobile Hotspot again to see or change the network name and password.
Other devices can now find your Samsung phone in the Wi-Fi list and connect.
The way you hotspot on your Samsung phone can sometimes to slightly different depending on on which device you've got. Need an upgrade? Check out O2 Samsung deals.
Hot to hotspot on Google Pixel
Open Settings on your Pixel.
Tap Network & Internet > Hotspot & tethering > WiFi hotspot.
Switch the Wi-Fi hotspot toggle to On.
Tap Hotspot name to set your network name (SSID).
Under Security, choose WPA2/WPA3 and create a strong password.
(Optional) Adjust Hotspot frequency: use 2.4 GHz for compatibility, or 5 GHz for faster speeds.
On the device you want to connect, open WiFi, find your hotspot’s name, and enter the password.
When you’re done, toggle the hotspot Off to conserve data and battery.
One thing to consider if you're planning on ordering the Pixel 10 or Pixel 10 Pro is that they both support Qi2 15W wireless charging, while the 10 Pro XL supports Qi2 2.2 25W, which could be beneficial for charging while using the device as a hotspot.
The Pixel 10 Pro and 10 Pro XL also support WiFi 7, offering potentially faster and more efficient connections when using the hotspot with compatible devices.
How to hotspot on other other Android Phones (Pixel, OnePlus, etc.)
Open Settings.
Tap Network & Internet or Connections, depending on the phone.
Select Hotspot & Tethering.
Tap Wi-Fi Hotspot (sometimes just called Hotspot) and turn it on.
You’ll see or can set the network name and password.
Use this info on another device to connect via Wi-Fi.
Things to consider when you set up a hotspot
There's are a few important things to consider if you want your hotspot to work as it should while you're connected. For one, keep in mind that using your phone as a hotspot uses your mobile data, and if you have a limited data plan, your hotspot might eat through your data quickly, especially if you’re streaming videos, downloading files, or browsing heavily.
Another thing to consider is your phone’s battery life. Hotspot mode can drain your phone’s battery quickly because it’s using both mobile data and Wi-Fi at the same time. To avoid running out of power, it’s a good idea to keep your phone plugged into a charger while using it as a hotspot.
You should also think about the strength of your phone’s signal. If you don’t have a strong 4G or 5G connection, you’ll likely get slow internet speeds or even make your hotspot connection drop out. And if you’re in an area with poor signal strength, your hotspot might not work at all.
Stay connected anywhere with Volt
A better, faster, and more reliable hotspot is just a tap away with Volt by Virgin Media O2. Volt gives you our ultrafast broadband, award-winning TV, and an O2 SIM in a single, supercharged package, that brings you lightning-fast speeds whether you're at home, on the move, or traveling.
Check out all of our broadband and SIM deals with Volt and enter your postcode to see all of the packages you can get in your area.
Browse the Virgin Media range
