  • Help
  • How to deal with fraudulent calls'
Have you recently been called by someone who’s told you they are from Virgin Media, but you are unsure? Or claiming your computer has been reported due to a security issue?
These calls may be a type of scam called Vishing – where a caller will attempt to trick someone into providing financial and private information or access to a computer system, for potential identity theft.
If you receive one of these calls and believe your computer(s) or data is not secure, we’ve listed some advice about how to respond.
If you ever receive a call from someone you think might not be genuine:
  • Always confirm the identity of the caller, take their name, company and contact details
  • If they are allegedly calling from Virgin Media, and you have a concern over their identity, inform them you will be hanging up and calling us directly to validate the call
  • Never provide financial details over the phone, unless you are 100% sure you know the caller
  • If in doubt, ask them to put the information in writing and end the call
If you have spoken to someone that you now believe to be fraudulent and have been asked to install computer software, here are some simple checks you can carry out:
  • Run a virus check on your computer
  • Remove any unwanted software that may have been installed
  • Report the fraudulent caller
Your computer could be infected with malicious software (malware) and so we recommend running a security scan on the machine as soon as possible. If you have security software already installed, there should be an option to “Scan Now”. Use this option to run a full scan of the system.
If you do not already have anti-virus software, we have teamed up with Virgin Media Internet Security to provide our broadband customers with Virgin Media Internet Security. This protects you and your family online anywhere, and on any device. You can find and download Virgin Media Internet Security from My Virgin Media.
To find out more about Virgin Media Internet Security, see Introducing Virgin Media Internet Security. We recommend running a full computer scan once it’s finished installing.
The caller may have asked you to download and install software on to your computer. The software usually allows the caller to log in and control your computer remotely. If their instructions were followed, we highly recommend that you remove this software as soon as possible. If you need to remove any software from your computer(s), the following guidelines may help.
Windows 10
  • Click the Start button at the bottom left of the screen
  • Select Control Panel
  • When the Control Panel appears, choose Uninstall a Program from the Programs category
  • Select the program you want to remove, and click Uninstall
Windows 8.1
  • Click the Windows icon in the screen’s bottom-left and choose the Control Panel from the pop-up menu
  • When the Control Panel appears, choose Programs and Features
Windows 7 and Windows Vista
Click the Windows icon in the screen’s bottom-left and choose the Control Panel from the pop-up menu.
In Large, Small icon or Classic view, click Programs and Features. If you’re using Category or Control Panel Home view (under Programs), click Uninstall a program.
Select the program you want to remove and click Uninstall.
Alternatively, right-click the program and select Uninstall.
How to report a fraudulent call
You can make a complaint and report a fraudulent call online. To do this, visit actionfraud.police.uk
If you want to know more
For independent advice on protecting yourself online, check out: getsafeonline.org or Ofcom's website
Other ways to get help
    Service status
  • Run tests on your kit
  • Identify network outages
  • Book an engineer
     Check service status
   Guided support
  • Browse help articles
  • Easy to follow videos
  • Step by step guides
     Get help
    My Virgin Media
  • Make a payment
  • Track your orders
  • Check service status
    Sign in
    Mobile Your Account
  • View mobile bills
  • Change your plan
  • Check balance
     Mobile Sign in
