  • Help
  • Personalise TV Box
How do I personalise my Virgin TV box?
Which one do you have?
Virgin TV 360 Box
Favourite channels
To set favourite channels, first you need to set up a profile.
How do I set up a profile?
  1. Press the  button on the side of the 360 remote
  2. Select the  (or the big + sign to add a new profile)
  3. Select the pen symbol under the profile name (or go through the new profile set up if you selected the +)
How do I add favourite channels?
  1. Go to Manage channels (or select Create List if you just created a profile)
  2. Select each channel you want by pressing OK on the 360 remote. You should see a heart symbol appear next to the channel.
  3. Once you have at least 3 channels, press the Back button, and then select on the bottom left button underneath the OK button on the 360 remote. Now your favourites will be saved.
  4. To view your favourite channels, simply press the profile button on the side of the remote and select your profile.
How do I rename the 360 box?
To rename the 360 box:
  1. Select Home on the 360 remote
  2. Select Settings
  3. Select System
  4. Select Rename boxes
TiVo
Other ways to get help
    Service status
  • Run tests on your kit
  • Identify network outages
  • Book an engineer
     Check service status
   Guided support
  • Browse help articles
  • Easy to follow videos
  • Step by step guides
     Get help
    My Virgin Media
  • Make a payment
  • Track your orders
  • Check service status
    Sign in
    Virgin Mobile Account
  • View mobile bills
  • Change your plan
  • Check balance
     Sign in
