Virgin Media O2 Logo in white
Everything you need to know about smart home devices
Household gadgets are getting clever and installing the best smart home devices can help you manage your life like never before
By Virgin Media Edit
Published
24 April 2025
What is a smart home device?
A smart home device is an internet-connected gadget that allows you to control something in your home – temperature, lights, music, blinds, locks, etc – via an app on your tablet or smartphone. It doesn’t matter whether you are in the property, on your way to the property or lazing on a beach in Lanzarote, you will always be in control.
What are the most popular smart home gadgets?
Many people start with smart lights because they are a relatively inexpensive way to begin your smart home journey. Smart security systems are also a popular early take-up as house-proud people like to monitor their homes from afar.
Voice-activated smart speakers represent a great way to show off the beginnings of a home automation adventure. There are lots of options to get you started though, it just depends what your priorities are.
What kind of broadband speed do I need to help run my smart home?
The faster the broadband you have connected to your home, the more devices you can connect without negatively impacting speed or performance. It’s not much use having the most up-to-date internet-connected home gadgetry if your broadband speed can barely handle your devices.
Some frequently asked question about smart gadgets
It’s only natural to be sceptical about new things, to question whether you personally – or society as a whole – really needs them and how you might decide to join the party.
Are smart devices really worth it?
Smart home installations are about personal choice and self-improvement. Early tech adopters might get a lift by being the first people on the estate to have automatic locks on their doors and the Ring home security service on their doorbell.
List lovers might want a voice-activated smart speaker to help them organise their lives in new and exciting ways. Cat connoisseurs might view a smart feeder as an essential addition to their garden so they can interact with their pets from afar and make sure they are okay.
What we do know is that in the future more and more houses will begin to have smart devices as standard as will workplaces and public places, so being prepared for smart gadgets to gently infiltrate your world is probably a good way to be.
What smart devices work together?
There’s a number of devices on the market that run different operating systems made by different companies that don’t always communicate, making it hard to hook up to a coherent system that can be controlled from one hub or application. After all, there’s nothing too clever about having to use multiple apps on multiple devices to control your home.
Which means the first thing you need to do when looking at buying smart home devices is to check their compatibility. A good way to start is to choose which smart speaker or advance controller you think is best for you and concentrate any subsequent buying decisions around compatibility with that device. Naturally, Google Home works seamlessly with Google Nest Hub Max and Google Chromecast, but it will work equally smoothly with Philips Hue White Starter Kit, Wemo WiFi Smart Plugs and Arlo Q security cams.
There are way too many combinations and permutations of smart devices to list what the best combinations are here, the best advice we can offer is this: choose an operating system – the most popular and wide-ranging are Google Assistant and Alexa – and then base your subsequent purchases around that initial choice.
What is the best internet speed for smart homes?
There are many different broadband setups, promoting many different speeds available on the market that will affect how you use and enjoy the internet in your home, including any smart devices you may own. The golden rule is this: the faster and more reliable your broadband connection the better it is for using multiple devices in multiple rooms all at the same time all day long.
Great home automation devices
Don’t worry if you’re a smart home novice, it won’t take long to learn the lingo and discover your options. Setting everything up is much easier than it probably seems, too. Depending on your area of smart home interest, here’s some best-in-class smart home gadgets to point you in the right direction.
Shaped like a veritable crystal ball, the 4th Gen Amazon Echo is a Bluetooth speaker handled by Amazon’s excellent voice assistant, Alexa. She’ll learn more about your voice and the way you speak the more you communicate with her and subsequently carry out all her tasks more efficiently the more time you spend together.
Google Nest Hub Max features a smart display that also doubles as a home security camera – handy for any room in the house. You can find out the latest news, the weather, see who’s in your home and it features a pretty decent sounding speaker to boot.
The Nest is great for energy-conscious smart home enthusiasts and is the most popular smart home thermostat solution for a reason: you can monitor daily energy usage and program temperatures using an incredibly user-friendly interface in the mobile app.
The Philips Hue smart light set-up allows you to adjust the lighting in your home to make it look like you’re there when you’re not, gently dim lights as you approach bedtime and brighten them as you wake up, sync mood lighting to your movie collection and generally regulate your lighting home set-up to within an inch of its ambient life.
Transform your home into a smart haven with Virgin Media
Explore the top smart devices—from lighting and security to entertainment—and see how Virgin Media's ultrafast broadband can seamlessly connect them all. With our reliable connectivity, your smart home setup will be more efficient and responsive than ever.​
Discover broadband plans
Browse the Virgin Media range
