Get the best WiFi connection in every room
Position your WiFi Hub and WiFi Pods around your home according to these dos and don’ts to help with getting the best possible connection in every room
By Virgin Media Edit
- Published
- 18 March 2026
Few things are more frustrating than your WiFi connection dropping out. Fast, reliable internet throughout our homes makes everyday life run more smoothly, which is why we’ve introduced our WiFi guarantee with WiFi Max. That means superfast, reliable broadband – and it’s our promise that you’ll enjoy download speeds of at least 30Mbps in every room or get £100 bill credit.
This goes hand in hand with our self-optimising Intelligent WiFi that’s loaded on our Hub 3, 4 and 5 and adapts to what’s happening in your home to give you the most reliable WiFi, all the time. You can also add our WiFi guarantee with WiFi Max to our M50 to M500 Fibre Broadband packs (without Volt) for £8 a month.
We’re revolutionising the way we keep people online, and our high-tech solutions will make your Virgin Media WiFi even faster and more reliable. But there’s also another surprisingly simple method that could give your signal a bit of a boost: moving your router. Follow these dos and don’ts, and you might find that you can stretch your WiFi further than expected…
Do… stay central
The best place for your router is right in the heart of the home. Imagine your ideal signal range like a huge bubble that surrounds your entire living space. If your WiFi router isn’t broadcasting from the bubble’s central point, your entire home is less likely to be covered by your internet connection.
Don’t… hide your Hub
Some people are tempted to tuck their internet router away for aesthetic reasons, but stowing yours in a cupboard or box is a surefire way to weaken your internet connection because any physical obstruction around your Hub will interfere with the signal. (It also increases the chance of the router overheating, which isn’t good.) For the same reason, you should avoid hiding pods behind furniture, especially bulky pieces like heavy chests of drawers or sofas.
Don’t… put your Hub near trouble spots
There are other places to avoid putting your router (if you can, bearing in mind it’ll need to be near the network’s entry point into the property). Don’t put it in the kitchen if possible, because heavy-duty metal appliances – ovens, fridges, washing machines – and signal-emitting electronics like microwaves can interfere and make this a particularly inhospitable environment for your router.
Fish tanks and mirrors are also the enemies of home broadband: water inhibits WiFi signal, and reflective surfaces (including stainless steel countertops and the like) can reflect the radio waves used to transmit wireless internet, which can have a negative impact on performance by scattering and distorting the signal.
Do… position your Hub higher
Remember that huge bubble that surrounds your entire living space? By placing the Hub higher, you’re effectively wasting less of the bubble. Try positioning the Hub high on a wall using an unobtrusive mount or small floating shelf – lots of retailers now make these especially for this purpose – or high on a bookshelf, where it can blend in with the books behind it.
If you in live in a home with multiple floors, the best position for the Hub might in fact be on the ground on the first floor. And you’re still using height to your advantage.
Do… give it space
WiFi routers aren’t team players – they generally prefer to operate at a distance from their fellow electronic devices. If your connection is weak, check to see if your Hub is too close to objects that send out their own signals, such as TVs, wireless speakers or cordless phones. It will be happier if it’s at least one metre away from other electronics.
Don’t… go horizontal
Keep your router upright with the front lights facing into the room to ensure the WiFi antennas inside the router are in the most efficient orientation and less of your WiFi signal is wasted. Having the router upright will also ensure optimal air flow through the Hub and help avoid overheating.
Do… make the best use of WiFi Pods
If you have trouble with WiFi around your house, you can take advantage of our WiFi Pods which are part of our WiFi Guarantee with WiFi Max. Here’s a handy guide to finding out if you need them. If you do have WiFi Pods, place them halfway between the Hub and the WiFi blackspot.
If you’ve got WiFi Pods on multiple floors, the best place for them is one directly above the other, or as close as you can manage. As with the Hub, avoid placing them behind furniture, near electrical appliances, in bathrooms or in other places that could mean the signal gets blocked.
Want to learn more?
Find out more about our fast WiFi guarantee and our WiFi Pods and see what you can do.
Virgin Fibre areas only. WiFi Guarantee available with M50 broadband or faster. £8p/m extra or included with Gig1, Gig2 or Volt. At least 30Mbps download speeds in every room or £100 one-off credit. Up to 3 WiFi Pods if needed. Exclusions & legal stuff apply.
WiFi Guarantee with WiFi Max: Available to Virgin Media residential broadband customers on M50 broadband or faster. Excludes Essential broadband customers. Existing Intelligent WiFi Plus customers will be individually informed when they are moved to WiFi Max. £8 a month add-on or at no extra cost for Ultimate Oomph, Gig1, Gig2 and Volt customers. WiFi Max is only available to order once your Virgin Media broadband service has been activated. If you don’t get download speeds of at least 30Mbps in every room, if needed we’ll provide up to 3 WiFi Pods. If that still doesn’t do the trick we’ll give you a one-off credit of £100 off your next bill. Guarantee and eligibility for pods does not cover broadband faults or network outages. Pods subject to stock availability, require self-installation via QuickStart and can be delivered via Click & Collect or optional home delivery (£5 delivery charge may apply). Pod type provided may differ from image shown. Improved WiFi performance compared to use without pods. Home environment, device limitations, number of users and time of day may affect WiFi performance. User speed varies and depends on Pod/Hub location, as well as broadband package choice. Equipment remains property of Virgin Media. Exclusions and further terms apply.
My Virgin Media app: Requires compatible Android 6.0 or iOS 11 or later mobile or tablet.
Broadband, TV and home phone customers: The app will work on a device (iPhone, iPad, Android phone or tablet) where sign in has been completed using My Virgin Media account details. It’s not always possible to guarantee that we’ll be able to offer this app on every device, platform and operating system version or variant. Terms and conditions apply. Further Legal Stuff applies – see https://www.virginmedia.com/legal
