Getting your device online
From your mobile home screen swipe either up or down to access apps
Step 1
From the home screen swipe either up or down to access apps
Tap Settings
Step 2
Tap Settings
Tap Connections
Step 3
Tap Connections
Tap Wi-Fi
Step 4
Tap WiFi
Tap the network you'd like to connect too
Step 5
Tap the WiFi network you'd like to connect to, your WiFi network name and password are shown on the bottom of the Hub.
Enter the password and tap connect
Step 6
Enter the password and tap CONNECT
Has this solved your issue?
