Getting your device online
Lets get your device online! Follow the steps below to get up and running in no time!
From your mobile home screen swipe either up or down to access apps
Step 1
On your keyboard press the Windows key and A to bring up the Action Centre then click expand.
If you're using an older version of Windows you can find the WiFi icon on the bottom toolbar of your desktop screen.
Click on the WiFi Icon
Step 2
Click on the WiFi Icon.
Click on your WiFi network name, check the Connect automaitcally box and then click Connect.
Step 3
Click on your WiFi network name, check the Connect automatically box and then click Connect. Your network name and password can be found on the bottom of the Hub.
Enter the password and wait for the connection to establish
Step 4
Enter your password and wait for the connection to establish.
Has this solved your issue?
