  • Help
  • Broadband phone
Setting up a new Hub
hub3
Follow our step-by-step guide to get the new Hub set up in no time.
You should have everything you need to get set up in your QuickStart kit.
But, if you're replacing the Hub for a new one, check out replacing an existing Hub instead
Did you know?
Our cardboard packaging is fully recyclable, so pop it with your other paper waste once you’re done.
Other ways to get help
    Service status
  • Run tests on your kit
  • Identify network outages
  • Book an engineer
     Check service status
   Guided support
  • Browse help articles
  • Easy to follow videos
  • Step by step guides
     Get help
    My Virgin Media
  • Make a payment
  • Track your orders
  • Check service status
    Sign in
    Virgin Mobile Account
  • View mobile bills
  • Change your plan
  • Check balance
     Sign in
