Mobile/Desktop only wrapper - from Extra small breakpoint - to Small breakpoint
Plug the cables into
the V6 box
Start by connecting the white cable with the white label into the V6 box.
Then grab the other end of the yellow Ethernet cable and pop that in, too.
Next take your TV’s HDMI cable and plug it in to the V6 box’s HDMI port.
After that, connect the power cable with the yellow label. And you know the drill – please don’t plug the power cable into a plug socket yet.
hub3
Mobile/Desktop only wrapper - from Small breakpoint - to No limit breakpoint
Plug the cables into the V6 box
hub3
