Mobile/Desktop only wrapper - from Extra small breakpoint - to Small breakpoint
Plug into the Virgin
Media wall socket
Push the white isolator cable with the black band  into the slot in the splitter marked ‘Wall’.
Then take the red-banded end of the isolator cable, and plug it firmly into the Virgin Media socket on your wall.
Some flats or apartments may have this style of socket rather than the one shown on the left.
Wall socket
hub3
Handy tip
If there’s already a cable plugged into your Virgin Media wall socket, use the spanner supplied in the box to remove it.
Mobile/Desktop only wrapper - from Small breakpoint - to No limit breakpoint
Plug into the Virgin Media wall socket
hub3
Wall socket
Handy tip
