Your Pay As You Go mobile plan is changing
What’s new?
From 18th November 2019, your Pay As You Go mobile plan will work a bit differently. This will affect how much you pay for your calls and texts.
Every day, the first 200 minutes of calls you make will cost £2 total, and then 1p a minute after that. This includes calls to landlines including calls to the Channel Islands and Isle of Man (starting 01, 02 or 03), Virgin Mobile phones and other UK networks. It means even if you make one 5-minute call a day or a couple of calls up to 199 minutes total a day, you’ll still pay the same £2.
It’s the same for the first 200 texts you send. They’ll cost £2 total, and then 1p a text after that. It means even if you send one text a day or 199 texts a day, you’ll still pay the same £2.
Your data will still cost the same. That’s £2 total for the first 200MB of data you use every day, and then £2 for the next 200MB after that.
If you’re happy with the change, there’s nothing you need to do. Your plan will swap over automatically.
Looking for something different?
If you’d like something that might work better for you, try our monthly JAM Packs. They give you better value on calls, texts and data, and refresh automatically every 30 days, as long as you have enough top-up credit in your account.
You can choose from:
250 minutes, 250 texts, 250MB data for £5.
500 minutes, 500 texts, 2GB data for £10.
1,000 minutes, 1,000 texts, 6GB data for £15.
2,000 minutes, 2,000 texts, 10GB data for £20.
You can add one of our JAM Packs to your mobile plan from 18th November 2019
Check out our JAM Packs
We hope you’re happy with your Virgin Mobile services, but if you’d like to leave us because of this change, head to our Switching Hub for more info or call us for free on 789. Make sure you use up all your credit before you leave or call 789 for a refund.
Check out our Standard UK charges in the table below:
Standard UK charges
Daily Plan
Calls to UK Landlines1 including calls to Channel Islands and Isle of Man (starting 01, 02 or 03)
£2 per day for up to 200 minutes
1p per minute thereafter
Calls to Virgin Mobiles and other Network Mobiles
Calls to Mobiles within Channel Islands and Isle of Man2
40p per minute
Calls to Virgin Media Directory Enquiries (118180)
150p per minute plus 36p per minute access charge
Voicemail Retrieval
26p per call
Calls to Freephone numbers (beginning 116, 0800, 0808)
Free
Calls to Virgin Media on 789 whilst in the UK (including pre-recorded Information)
Free
Calls to 101 (Police non-emergency)
Free
Calls to Emergency Services (999, 112)
Free
Access charge for numbers beginning with
084, 087, 09 & 1183
36p per minute access charge plus service charge
Text Relay Service to Landlines and Mobile
£1 per day for up to 200 minutes
0.5p per minute thereafter
Calls to Satellite Phones
613p per minute
Video Calls to Virgin Mobiles and other Network Mobiles
Personal Numbers (numbers beginning 070)
75p per minute
Pagers (numbers beginning 076)
Texts to all UK Network Mobiles excluding texts to Channel Islands and Isle of Man2
£2 per day for up to 200 texts
1p per text thereafter
Picture messages to UK Networks
30p per message. The cost of sending an MMS is 30p, but if your handset settings are incorrect you may incur the daily rate for data if you do not have a data allowance
Including calls to Channel Islands and Isle of Man
2 Channel Islands and Isle of Man Mobile ranges: 07937/ 079240 / 079241/ 079242/ 079243/ 079244/ 079246 / 079247/ 079248/ 079249/  074184/ 074520/ 074521/ 074522/ 074523/074524/ 074525/ 074526/ 077003/ 077007/ 077008/ 077810/ 077811/ 077812/ 077813/ 077814/ 077815/ 077816/ 077817/ 077818/ 077819/ 079111/ 079117/ 075090/ 075091/ 075092/ 075093/ 075094/ 075095/ 075096/ 075097/ 077977/  077978/ 077979/ 078297/ 078298/ 078299/ 078391/ 078392/ 078397/ 07624/ 079788/ 078398
3 The cost of calling these numbers will be formed of a combined access and service charge: we set the access charge and the company you’re phoning set the service charge. Your access charge for these numbers will be shown on your bill and is 36p per minute. The service charge will be advertised by the company that you are calling.
Need more help
    Ask our community
  • Helpful, friendly forums
  • Packed with tips and advice
  • Staffed by Virgin Media
    Contact us
  • Get in touch with our friendly team
  • Waiting times may vary
  • Free from Virgin Media phones or mobile
