Does weather affect your broadband?
Rain, heat, storms... can they really affect your broadband connection? Learn what keeps your WiFi running smoothly whatever the forecast is
By Virgin Media Edit
- Published
- 10 April 2026
Ever wondered if bad weather is slowing your internet down? From heavy rain to strong winds, the weather outside can affect how signals travel, how networks perform, and how hard your connection has to work to keep up, but not always in the ways you'd think.
Let’s break down what’s really going on behind the scenes, and why your broadband is built to handle far more than a bit of British drizzle.
Can weather really affect my broadband?
The short answer is: yes – but it doesn’t happen very often, and it depends on the kind of broadband you have at home.
Very severe weather, like torrential rain, strong winds, flooding, or major storms, can occasionally cause problems with broadband infrastructure. This is more likely with older connections that rely on phone lines or exposed copper cables, which are simply more vulnerable to the elements.
That said, these kinds of disruptions are uncommon and, when they do happen, they’re usually resolved quickly by network engineers.
The WiFi router that keeps you connected itself is safely tucked away indoors, protected from rain, wind, and temperature changes. So if your WiFi seems slower than usual on a drizzly Tuesday afternoon, it’s not very likely that the weather is to blame.
More often than not, the slowdown has a much simpler explanation. Lots of devices using the internet at once can easily stretch your bandwidth – especially if people are streaming TV, working from home, gaming online, or downloading large files.
So while Mother Nature can occasionally cause issues during really severe conditions, most broadband networks are built to cope with everyday UK weather without a problem.
How each type of weather affects your broadband
Here’s a breakdown of how various weather conditions can impact your connection, and why, in most cases, modern networks handle them with ease:
Rain, wind and storms
Heavy rain and storms can sometimes affect your broadband, but it really depends on the type of connection you have. Older, copper‑based networks like ADSL and FTTC are more likely to be affected by water, especially if the cables are already worn or regularly exposed to the elements. Strong winds can also cause issues by moving overhead lines or damaging outdoor equipment that these older connections rely on.
Modern fibre networks are built to be far more resilient. For most homes, even during a proper downpour, you won't notice any changes to your connection.
Heatwaves and hot weather
Hot weather very rarely has any noticeable impact on your broadband. The network and equipment are designed to work reliably in everyday conditions, so most people won’t see any change in performance, even during warmer spells.
In general, broadband equipment is built to cope with heat. Making sure your router is placed somewhere comfortable and not overly cramped can help it run at its best, but there’s usually nothing you need to worry about. Your connection should continue to work as normal.
Snow and cold temperatures
Cold temperatures alone rarely affect broadband performance. In fact, fibre networks are generally very stable in colder conditions.
Where snow can cause issues is if it leads to physical damage – for example, fallen trees or ice affecting external infrastructure.
Tips to protect your broadband from the elements
Most of the time, your broadband is built to handle whatever the forecast throws at it. But in more extreme conditions, like flooding or lightning strikes, weather can have an impact, usually by affecting the infrastructure that keeps you connected.
There are simple ways to reduce the risk and keep things running smoothly:
Fibre networks are more resilient to extreme weather than older copper connections, helping give a more stable experience no matter the weather. You'll also get faster, more consistent speeds, meaning even if the weather outside is stormy, your streaming, gaming, and work calls stay stable.
Storms and high winds can sometimes damage street cabinets and down cables. If you notice any visible damage or your connection drops for an unusual length of time, report it to your provider straight away. The sooner the issue is flagged, the faster it can be repaired, reducing downtime and keeping you online.
Why your home setup matters more than the forecast
Most broadband issues that feel weather-related actually start inside the home. Think of thick walls, device overload and Hub placement, which can have a much bigger day-to-day impact on your connection than whether it’s raining outside.
A few simple tweaks can go a long way:
Keep your Hub in an open, central location
Avoid placing it near large metal objects or behind furniture
After storms or strong winds, make sure cables are secure and undamaged
Limit interference from too many connected devices at once.
Get the UK's most reliable broadband
Looking for broadband that you can rely on? We've been named the UK’s most reliable broadband provider for two years running, driven by our continued investment in our fibre network.
Our network is built on gigabit-capable infrastructure and Intelligent WiFi that keeps your connection running smoothly, rain or shine.
Looking to make the switch? Explore our best broadband deals and pop in your postcode to see what's available where you are.
More broadband tips, tricks and stories
