Virgin Media O2 Logo in white
What’s the best broadband for working from home?
Working remotely? You’ll need a broadband connection that’s fast and reliable to handle video calls large files and everything in between. Here’s how to choose the best broadband for working from home and how much speed you’ll need
By Virgin Media Edit
Published
10 April 2026
The Low-Down...
  • Most people need 50–100 Mbps for smooth remote work like emails, browsing and occasional video calls
  • Busy households with multiple users should aim for 100-200 Mbps and more to avoid slowdowns when streaming, gaming and working at the same time
  • Fibre broadband offers the best reliability for video calls and large file downloads, reducing buffering, lag and dropouts
  • A wired connection or optimising your WiFi setup can improve performance
Do I need fast broadband to work from home?
You may well do! Fast broadband is important for working from home because it helps you stay connected to your colleagues and do your work more efficiently.
With a fast and reliable broadband connection, you can:
  • Upload and download files quickly
  • Join video calls without freezing or dropouts
  • Use cloud-based tools without delays
Slower internet can lead to buffering, poor call quality and wasting time waiting for things to load, especially if multiple people in your home are online at the same time.
Fast broadband ensures that everyone can use the internet at the same time at home without interruptions or slowdowns, providing you with a stress-free working environment so that you can focus on your job without technical difficulties.
What broadband speed do I need to work from home?
The best broadband speed for working from home depends on what you do and how many people share your connection.
  • Basic tasks: If your day mainly involves sending emails, browsing the web, or using office apps, speeds around 50-100 Mbps are usually enough.
  • Video calls and cloud software: For regular meetings or collaborative tools like Google Drive or Microsoft Teams, aim for 100 Mbps or more to avoid lag.
  • Creative or technical work: If you’re a designer, video editor, or software developer regularly handling large files, you’ll benefit from faster fibre speeds (300 Mbps+).
Also, think about who else is online. If your family streams, games, or studies at the same time, faster speeds keep everyone connected without slowdowns.
Pro Tip: Want to have a look at what speed you really need? Check out our guide to all the different broadband speeds.
How can I improve my home-working WiFi setup?
To improve your home-working internet setup, start by ensuring you have a fast and reliable broadband connection. You can also optimise your WiFi connection to make sure it reaches every part of your home. Try these tips:
  • Place your router in a central location in your home for better coverage.
  • Use a wired Ethernet cable for important tasks like video calls or large uploads.
  • Pause heavy internet use (such as streaming or gaming) during work hours.
  • Upgrade your router if it’s old, as newer models offer faster speeds and better coverage.
  • Use a WiFi extender or mesh network if your home has weak signal areas.
For more tips, see our guide on how to improve internet speed.
If your internet still struggles after optimising your WiFi setup, it may be time for an upgrade. We’ve got a range of superfast options to suit every home, and thanks to One Touch Switch, it’s now easier than ever to switch to Virgin Media.
Take a look at our broadband deals and compare our speeds to find the best package for you.
Upgrade your broadband
What’s the best broadband package for working from home?
The best broadband for working from home is one that is fast, reliable, and has enough speed for all of your daily tasks. Full fibre and cable broadband are both strong options, offering high speeds and stable connections that can handle video calls, large file downloads, and multiple users.
Fibre broadband with at least 100 Mbps is ideal for most remote workers, but you may need higher speeds if multiple people in your home are using the internet at the same time while you’re working.
Not sure what you can get at your home? Use our helpful broadband postcode checker to see all of the packages available in your area.
Check your postcode
Things to look for when choosing broadband for working from home
Working from home smoothly depends on more than just having a broadband connection. From speed and reliability to upload performance and router quality, different factors can affect how well your internet handles video calls, file sharing, and multitasking.
When working from home, you need a broadband connection that is fast enough for your daily tasks. We’d recommend a speed of at least 50-100 Mbps for smooth video calls, file downloads, and multitasking all of your different tasks at once. If multiple people in your home use the internet at the same time, you may need 100-200 Mbps to avoid slowdowns.
A stable internet connection is just as important as speed. Frequent disconnections or slowdowns can interrupt video meetings and affect your productivity. Fibre-optic broadband is the most reliable option because it provides a steady connection, even during peak hours. If fibre isn’t available, cable broadband is a good alternative. Check customer reviews to see how reliable a provider is before choosing a plan.
Most people focus on download speeds, but upload speed is just as important for working from home. If you send large files, upload videos, or regularly join video calls, a good upload speed is key for your files to upload quickly and your video calls to stay crystal clear.
If others in your home are using the internet for streaming, gaming, or online classes, your connection might slow down. In a household with multiple users, choosing a higher-speed plan (200 Mbps or more) helps ensure that everyone has a smooth experience. Some broadband providers offer plans designed for homes with many connected devices.
Your router plays a big role in how strong and stable your WiFi feels at home, especially in larger homes or areas where the signal drops off, also known as “dead spots”. Upgrading to a newer, high-performance router can boost speed and reliability across all your devices.
For even better coverage, consider a mesh WiFi system, which can extend coverage seamlessly across every room.
No-contract broadband deals
What's the best backup internet for working from home?
It's always a good idea to have a backup plan. You can use a mobile hotspot to work from home, but it depends on your internet needs. A mobile hotspot uses your phone’s data connection to provide internet access, which can be useful if you don’t have broadband or need a backup.
Using your phone's data or a WiFi dongle works well for basic tasks like checking emails, browsing websites, and using online documents, but if you need to make video calls, download large files, or use cloud-based software, a hotspot may not be fast or stable enough.
You’ll also have to consider if you have any data limits and signal strength. Many mobile data plans have a limit on how much high-speed internet you can use before speeds slow down, which can make working difficult over long periods. Some network providers offer unlimited hotspot plans, but they may still reduce speeds after a certain amount of usage.
What are my broadband options if I work in a rural area?
Broadband in rural areas can be slower because homes are often farther from telephone exchanges or local infrastructure is limited. The further the signal has to travel, the slower your connection may be.
If you’re struggling with speed, consider:
  • Mobile broadband: A good temporary solution if you have a strong mobile signal.
  • Satellite broadband: A longer-term option where fibre or cable isn’t available.
Virgin Media O2 is partnering with Starlink to launch O2 satellite in 2026, helping to keep people connected in remote areas where no terrestrial signal is available.
For detailed tips, see our guide to broadband in rural areas.
Upgrade your home-working setup with Virgin Media broadband
When it comes to broadband for working from home, we’ve got you covered. Our superfast fibre broadband is great for keeping your connection fast and reliable all day-long, featuring speeds of up to 1130 Mbps and beyond with our gigabit broadband.
And with our WiFi guarantee, you get the peace of mind that your internet will always be fast enough for all of your file downloads, video calls, and whatever else you need the internet for at work.
Check out all of our broadband deals and enter your postcode to see all of the packages available in your area.
Our broadband deals
Browse the Virgin Media range
