Virgin TV 360 is loaded with a handy way to start your shows from the beginning, even if you’re running late
By Virgin Media
Life doesn’t always overlap with the moments when you want to relax. Maybe your kids see bedtime as an opening offer, or perhaps that roast chicken the online recipe claimed would cook in under 30 minutes still looks like it needs a sunbed. Whatever your scenario, there’s no need miss a second of the shows you love.
With Virgin TV 360, there’s a handy function called Startover. Simply…
A. Press the Guide button on your Virgin TV 360 remote.
B. Select the show that has started using the arrow keys. If Startover is available, you’ll see the Startover logo next to the show’s title.
C. From here, you can select to Watch live or Watch from the start.
Did you know you can also get to the Guide at any point just by using your voice? Simply hold the microphone button and say, “Guide”.
Want even more Virgin TV 360 tips?
Want to discover the secrets of your new remote control, check out your channel guide or find out the best things you can ask your telly to do? Find all this and more here.
Virgin TV 360 Box: Minimum of M50 Fibre Broadband required for operation. Boxes require a HDMI cable to connect to your TV.
